Export locked video evidence
When you export evidence locks
A video sequence that is protected, so it cannot be deleted., also the data from devices related to the cameras is included in the export.
- Switch to playback mode.
- On the workspace toolbar in the upper-right corner, click Evidence lock and select View.
If you want to stay in live mode instead of in playback mode, select Evidence lock on the global toolbar.
A list of existing evidence locks with devices that you have permission to access appears.
Select an evidence lock and click Add to export list.
Continue with the export process. See Adjusting export settings and Create an export.
