Types of formats for exports
XProtect Smart Client enables you to export in one or more of the following formats:
| Format | Description |
| XProtect format |
Use the XProtect format to include the XProtect Smart Client – Player along with the export. The XProtect Smart Client – Player is the only media player that can play this format. To verify that the exported evidence has not been tampered with, select Export settings > XProtect format > Include digital signature. This setting enables the Verify signatures button in the XProtect Smart Client – Player. |
| Media player format |
Use a format that does not require you to know how to use XProtect, and that most media players can play. You only need to have a media player installed to play this format. There are two ways to export in media player format:
| Still images | Export a still image file from each frame for the time period you have selected. |
