Still image format settings
Choose the still image format to export a still image for each frame of each video sequence. The images are in the JPEG
An image compression method, also known as JPG or Joint Photographic Experts Group. The method is a so-called lossy compression, meaning that some image detail will be lost during compression. Images compressed this way have become generically known as JPGs or JPEGs. format.
Name |
Description |
| Include timestamps |
Add the date and time from the VMS system to the exported images. The timestamp will be displayed at the top of the exported images. |
