Document version
Ver.
Date
Section
Description
Author
1.0
February 2018
ONVIF/ONVIF16 driver overview
Magdalena Filcheva
Georgi Yanev
Maxim Zapryanov
Gabriela Tzanova
Reem Rady
1.1
March 2018
Edge storage for multichannel devices
Info about Aux Buttons renaming
Maxim Zapryanov
1.2
March 2018
Retrieval of remote recordings (Edge storage)
Requirements for Edge Storage on Multichannel devices.
Minor modifications.
Joanna Zdunek
1.3
May 2018
Add information about alternative fallback method for linking a recording to a Video/Audio source.
Maxim Zapryanov
Definitions
Does the ONVIF driver support Transparent PTZ?
Add information about Transparent PTZ.
Does the ONVIF driver support License Plate Recognition (LPR) or Automatic Number-Plate Recognition (ANPR)?
Add question about LPR/ANPR.
Does the ONVIF driver support B-frames?
Add question about B-frames.
HTTPS
Reorganize section.
Add clarification for Audio OUT (audio backchannel) over HTTPS.
Add information for version requirements for Audio Edge Storage
    Auxiliary
Additional information about types of commands that the driver accepts and assigned to the buttons in Smart Client
Magdalena Filcheva
    Setup of Aux buttons in the Smart Client
Events
Type of event’s negation
Line Crossed
Add new schema for Line crossed event
Intrusion Detector
Add new schema for Field detector event
1.4
August 2018
Video settings
Clarify multicast address setting
Magdalena Filcheva
Specify the default value and streaming method for Keep alive type setting
Audio IN/OUT
Add new value for audio bitrate (48 kbps)
Events
The value type (source) add and describe
Object counting
Add event “Object counting”
Recordings Available
Add event “Recordings Available”
SD Card error
Add event “SD Card error”
General device settings
Add “HTTPS Validate Certificate” and “HTTPS Validate Hostname” options
Maxim Zapryanov
HTTPS Certificates
Add new section for HTTPS Certificates
1.5
January 2019
Tampering
Add new schema for Tampering event
Magdalena Filcheva
SD Card Mounted
Add new event SD Card Mounted
Fix grammar
Maxim Zapryanov
Standard References
Add new section “Introduction”
Does the ONVIF driver support HLS?
Add question about HLS.
Does the ONVIF driver support MP4 or MKV containers?
Add question about supported containers.
Metadata
Add requirements for metadata channel to be shown in Management Application
Metadata
Add note about handling of metadata in streaming XMLs
Audio IN/OUT
Add note about Audio Out for multicast streaming and RTSP over HTTP.
Relay outputs
Add section for Relay outputs
1.6
July 2019
Detect Sound
Detect Sound Event
New attribute values for the Source
No more valid note: “The ONVIF driver cannot detect which audio source is triggering the event.”
Magdalena Filcheva
Media service
Add a note about Media Service and older Device Packs
HTTPS
HTTPS port is now read from the device when possible
Maxim Zapryanov
HTTPS
Add information about usage of “HTTPS Validate Certificate” and “HTTPS Validate Hostname” options.
Auxiliary
Add information Aux Commands in the Device Service (Available in ONVIF driver in Device Pack 10.3)
Also add clarifications and fix inconsistencies in the text
Add clarification about needed ONVIF services for Edge Storage support
ONVIF conformance
Update with information about conformance to latest ONVIF Client Test Tool 18.12 rev.2606
Metadata
Update screenshot of metadata settings
Detect Sound
Detect Sound Event – add new scheme
What is ONVIF?
New Introduction and scope. What is ONVIF? And Milestone ONVIF drivers
Magdalena Filcheva
Brute Force Attack
Add event “Brute Force Attack”
Cyber Attack
Add event “Cyber Attack”
Quarantine
Add event “Quarantine”
Audio IN/OUT
Splitting Audio IN/OUT settings in two different sections
Metadata
Add new metadata stream settings ‘PTZStatus’, ‘Events‘, ‘Analytics‘.
Tampering
Detect Sound
Extend the "Trigger/VolAlarm" schema with Data 1
Line Crossed
Add new schema for Line Crossed
Temperature
Add new schema for Temperature
Fire
Add new schema for Fire
1.7
November 2019
Metadata
Changed default values for streaming method to RTP/UDP
Magdalena Filcheva
Audio IN/OUT
Add new “Buffer size” setting for Audio Out
Why the ONVIF driver does not send PTZ Stop command?
Add FAQ about PTZ Stop command
Maxim Zapryanov
Standard References
Update references to used specifications
Events
Add note about SetSynchronizationPoint
Video settings
OSD – add settings and description
PTZ
Add information about the supported PTZ spaces
1.7.1
November 2019
Temperature
Add new thermal events
Magdalena Filcheva
1.8
March 2020
Standard References
Update to ONVIF Service Specification 19.12
Maxim Zapryanov
ONVIF conformance
Update with information about conformance with Profiles S, T, G and Q
Add information about Metadata Edge Storage support
H.265 video edge storage support
Margarit Nikolov
Edge Storage Retrieval and RTSP/RTP timestamps
Add section explaining handling of timestamps during Edge Retrieval
Georgi Georgiev
1.8.1
April 2020
Which ONVIF Profiles does the ONVIF driver support?
Update with Profiles S, T, G and Q
Maxim Zapryanov
What is ONVIF?
Add information about ONVIF trademark
1.9
June 2020
Edge Storage retrieval workflow
Update Edge retrieval diagram to show that the result of GetRecordingSummary is ignored
Gabriela Tzanova
Audio IN/OUT
Audio Backchannel codec selection
Update Audio Out section and add new section explaining the backchannel codec selection process.
Maxim Zapryanov
Auto Tracker
Add event “Auto Tracker”
Gabriela Tzanova
1.10
August 2020
Overview of factory default state
Add information about Factory Default state and Profile Q
Maxim Harizanov
1.11
November 2020
Overview of firmware update
Add new section for firmware upgrade functionality
Maxim Harizanov
Intrusion Detector
Rename “Field Detector” to “Intrusion Detector” and add two new schemas for detection – IntrusionStarted and IntrusionEnded
Maxim Zapryanov
Crowd Detection
Running Detection
CrowdDetection and RunningDetection events are added with Vivotek schema
Dayana Hristova
Home position
Add information about the command used for home position
Maxim Zapryanov
1.12
December 2020
Tampering
Add information about when to use Tampering Start and Tampering End events instead of just Tampering event
Magdalena Filcheva
Audio IN/OUT
Change Audio In settings of Encoding and bitrate to a combined setting of Codec/Bitrate.Samplerate
Maxim Zapryanov
1.13
February 2021
Does the ONVIF driver work with devices behind NAT and when port forwarding is used?
Configuration of devices behind NAT and port forwarding
Add new FAQ about devices behind NAT and add new section describing the different possible scenarios
Maxim Zapryanov
1.14
August 2021
Line Crossed
Intrusion Detector
Crowd Detection
Running Detection
Added new Source column for Intrusion and Line Crossed events to reflect the added windowed schema for Vivotek
Changed Crowd and Running detection event window parameter
Georgi Yanev
Motion
Detect Sound
Line Crossed
Intrusion Detector
Abandoned Detector
Missing Detector
Loitering Detector
Face
Object counting
Crowd Detection
Added Vicon special events support for Motion Detection, Sound Detection, Line crossed, Intrusion, Abandon Detection, Missing Detector, Loitering, Face Detection, Object Count and Crowd Detection
Dayana Hristova
Motion
Detect Sound
Missing Detector
Object counting
Added Pelco special events support for Adaptive Motion/Directional Motion, Audio Detection, Object Removed and Object Count
Dayana Hristova
Audio IN/OUT
Audio Encoder configuration is added by the driver, if there is at least one in the camera, but there isn’t any associated with the Media Profiles.
Dayana Hristova
Video settings
Fix references to Management Client
Updated Section Video Settings with PTZ Zoom Step setting description
Maxim Zapryanov
1.15
August 2021
Video settings
Updated Video Settings with PTZ Zoom Step setting description
Add information about PTZ Zoom Step value of zero
Gabriela Tzanova
Maxim Zapryanov
September 2021
Audio IN/OUT
Added supported by ONVIF driver codecs for Audio In and Audio Out
Dayana Hristova
October 2021
Missing Detector
Loitering Detector
Object counting
Stopped Vehicle Detection
Added New Pelco events for Object Missing, Loitering, Object Counting, Stopped Vehicle
Georgi Yanev
1.16 December 2021
Overview of dynamic events
Added new section “Dynamic events“ after the Events section effectively moving all following sections with one move index forward. Georgi Yanev
    Home position Clarify PTZ Home Position support by devices. Maxim Zapryanov
Tampering
Video Loss
Added ONVIF Specification Tampering schemes for “GlobalSceneChange” / “ImageTooDark” / “ImageTooBlurry” / “ImageTooBright” Added ONVIF Specification VideoLoss scheme for “SignalLoss”
Georgi Yanev
    ONVIF conformance Add Profile M Maxim Zapryanov
    Area Zoom
Area zoom implementation
Area Zoom
Georgi Georgiev
1.17 May 2022 General device settings
Add note about switching to Media 1 and H.265 codec
Maxim Zapryanov
1.18 August 2022 Audio IN/OUT Added supported by ONVIF driver codecs for Audio In and Audio Out Iliyan Ruykov
  October 2022 ONVIF PTZ Configurations Add section about ONVIF PTZ Configurations Maxim Zapryanov
  November 2022 ONVIF16 driver Update information on ONVIF Driver and multichannel devices Maxim Zapryanov
1.19 April 2023 Does the ONVIF driver support B-frames? Updated information on support of B- frames in XProtect and ONVIF driver Gabriela Tzanova
1.20 May 2023 Retrieval of remote recordings (Edge storage)
PTZ
Updated screenshots Petko Petrov
1.21 July 2023 Does the ONVIF driver support B-frames? Updated information on support of B- frames in XProtect and the ONVIF driver Gabriela Tzanova
  August 2023
ONVIF conformance
Update language around ONVIF conformance Maxim Zapryanov
  November 2023 Video settings Add information about new general setting “PTZ send zoom parameter” Gabriela Tzanova
1.22 December 2023 Area zoom implementation Add more details to the “Zoom Translation Space in FOV” section. Change in the proposed space URI name Gabriela Tzanova
