General device settings
The global settings for the device are settings that should be set once for all channels and streams. They are placed under the device item in “Settings” tab. When global settings change, major functionalities change as well. The following table contains the device’s general settings:
Setting name
Possible values
Value taken from device
Default value
Model name
Manufacturer name and model name
HTTPS enabled
No
Yes
No
HTTPS port
[1,65535]
443
HTTPS Validate Certificate
No
Yes
No
HTTPS Validate Hostname
No
Yes
No
Media Service
Media 1
Media 2
Media 2 service - if device supports it, else Media 1 service. See Section Media service
: Media Service should be changed only if there are known compatibility issues with the device with the default Media Service
: Changing the Media Service requires a Recording Server restart afterwards.
: When changing Media Service from Media 2 to Media 1, make sure to not have a codec set to H.265. Media 1 does not support H.265 and when using it some devices incorrectly report the current codec.
