ONVIF16 driver
The ONVIF16 driver is obsolete and is limited to 16 video/audio channels. The driver has the same settings and specifications as the generic ONVIF driver. The following sections describe the generic ONVIF driver. If there are other differences between the two drivers, except for the number of channels, they will be explicitly stated. The ONVIF Driver supports devices with up to 512 video/audio channels.
