Overview of factory default state
Profile Q conformant devices are in the Factory Default State when first connected to a network. This state is intended for initial configuration, and the device should be deployed only in Operational State.
The ONVIF driver supports Factory Default State detection for profile Q conformant devices and can also transition devices to the Operational State.
Factory Default State detection and initial configuration are supported as of Device Pack version 11.1 and XProtect version 2020 R3.
