Search for alarms
When you search for video recordings associated with alarms, you can apply search filters to show only search results with certain alarms, for example alarms in a certain state that are assigned to a specific operator.
Select the cameras that you want to include in your search.
Click Search for > Alarms > New search.
Apply search filters to narrow down search results. You can filter for:
Priority
State
ID - Type the full ID to filter for it
Owner
Server - available only if you are using Milestone Federated Architecture™
If you are using Milestone Federated Architecture™, the Priority and State filters are applied across all connected sites.
Click or scan:
