Actions available from search results
Based on your search results, there are multiple actions available. Some actions are available in the blue action bar, others in the preview area.
The actions available may differ depending on your user permissions.
Action |
Description |
Add the selected sequences to the Exports tab > Export list. All the sequences that you add to the Export list are ready for export on the Exports tab. See also Exporting video, audio, and still images. |
Create PDF reports with information about the search results, for example still images from the video sequences. |
Bookmark multiple search results at the same time. |
Edit multiple bookmarks at the same time. |
Add evidence locks to protect the video sequences and data from related devices, for example audio, from being deleted. |
Open multiple search results in a detached window, where you can view the video in live or playback mode, export, create evidence locks, and retrieve recordings from devices and cameras belonging to interconnected VMS systems. |
Take multiple snapshots of your search results at the same time. |
When you are previewing video, you can transfer the current time to the independent playback timeline. This is useful, for example, if you want to look at related cameras in playback mode at the time that an incident took place. |
There may be additional actions available, related to third-party software. The MIP SDK
Short for "Milestone Integration Platform software development kit". is used to add
these additional actions.
