Add video sequences to the Export list
You must add video sequences to the Export list before you can create the export. You can add files from several places in XProtect Smart Client:
From the Exports tab, in the Export list, select Add item to add the video sequences.
From the Search tab, for each search result to export, select the blue check box
, then select Add to export list in the blue action bar. To select all your search results, select one search result and press Ctrl+A. In the blue action bar that is displayed, select Add to export list
From the View tab, in Playback mode, you have two options for adding video sequences to the Export list:
Option 1:
In the timeline, select Set start and end time on timeline
to select the start and end time of the sequence to export.
For each item to include in the export, select the associated check box
. If you want to export all your search results at the same time, choose the Select all button
on the workspace toolbar in the upper-right corner.
Select Export > Export to add the selected video sequences to the Export list. This action automatically takes you to the Exports tab. Alternatively, select Export > Add to export list to add the selected video sequences to the Export list while you remain in playback mode and can add more sequences to the export list.
Option 2:
In the Evidence lock list, select an existing evidence lock.
Select Add to export list to add the selected video sequence with evidence lock to the Export list and to stay in playback mode, or select Evidence lock > View > Evidence lock list.
To export several video sequences from the same camera on the Export list, select the sequence and click the split camera icon .
Click or scan:
