What's new?
In XProtect Mobile client 2025 R2
Both iOS and Android
  • Live Picture-in-Picture (PiP) now works when you use gestures to control your device.
  • You can now use the same date format throughout the app and in your system settings.
Android
  • Letterbox improvements
    The user interface of the XProtect Mobile client app is now restricted to a certain width to maintain its original aspect ratio, preventing distortion or stretching on larger screens. The results is that you get blank areas on the sides, known as letterboxing.
  • Segmented buttons
    The drop-down menus have been replaced with segmented buttons for easier navigation and design consistency across Android and iOS. Segmented buttons are now used in:
    • Access control
    • Bookmarks (your choice of using either My bookmarks or All bookmarks) are remembered from your previous sessions).
    • Alarms
    • Investigations.
    Access control notifications
    If you have switched off notifications, you now get a warning message when you're in the access control screen.
iOS
  • Timestamps
    For consistency, the XProtect Mobile client app now follows the phone's timestamp format.
  • Letterbox Improvements
    Similar enhancements to those made on Android.
