BriefCam Administrator Guide
Environment Settings
All the environment settings are managed from the Environment Settings section, which is located in the Settings section. It is recommended to make the changes in this screen and not in the .ini files. Changes made to local settings will override the centralized ones.
Rows highlighted in grey are settings that have been changed. To see only these rows, click the Show settings that have been changed checkbox.
You can copy a value by hovering over a default value or value and clicking the copy icon (Environment settings copy icon.png).
There are some environment settings that appear more than once (as shown in the image below). The setting that is from a more specific type (such as Processing Server or VS-Server) overrides the more general setting (the Common type).
Note
JSON structures, such as the RestrictedGroupsSharingPolicies setting shown in the image below, can be edited directly in the environment settings by clicking the edit Edit icon white.png icon.
See also:
Session Timeouts and Locking Out Users
NAS Configuration
Storing of Artifacts
Filtering Settings
Fast Track Settings
Proximity Settings
Illumination Changes Class
Other Class
Rendering Settings
Processing Settings
RESPOND Alerts Settings
RESEARCH Settings
