Storing of Artifacts
Large blob artifacts (thumbnails, video clips) in the file system are not stored in the same folder. This solves the issue of performance bottlenecks, preventing folders containing millions of items in a large-scale environment. The folder depth is controlled by the LargeBlobTreeDepth environment setting.
The valid values are:
1– When the setting is set to ‘1’, the folder is divided into 100 subfolders.2- By default the setting is set to ‘2’, which creates a two-layer distribution. Each of the 100 folders can also have their own 100 subfolders for a total of 10,000 (100^2) subfolders.
