Find and open saved searches
You can find and open saved searches.
  1. On the Search tab, click to the right of Search filters.
    Search filters in XProtect Smart Client.
  2. In the list that appears, click Open and manage searches. A window appears.
    Open and manage searches in XProtect Smart Client.
  3. Find and double-click the search that you want to open, or click Open. Immediately, the search is run.
    If many searches are listed, you can use keywords to find the search. The search includes both the Name field and the Description field.
  4. You can modify the search, for example by adding cameras. Click > Save to save the changes.
