Change how a search is configured
You can change how the search is configured, for example the search categories.
  1. On the Search tab, click to the right of Search filters.
    Search filters in XProtect Smart Client.
  2. In the list that appears, click Open and manage searches. A window appears.
  3. Find and double-click the search that you want to open, or click Open. Immediately, the search is run.
    If many searches are listed, use the search function to find the search.
  4. Modify the search, for example by adding cameras, and click > Save.
