Edit the details of a saved search
You can change the details of a saved search.
The following user permissions are enabled on your role in XProtect Management Client:
- To edit a public search, the Edit public searches user permission must be enabled
On the Search tab, click
to the right of Search filters.
- In the list that appears, click Open and manage searches. A window appears.
- Find and select the search that you want to change.
- Make your changes, for example by entering a name for the search, and click Save.
