Remove live restriction
You can select and remove multiple live restrictions, but you cannot mix restriction types – that is select both playback and live restrictions for removal at the same time.
When a restriction on a live stream is removed, the recorded footage of the same video sequence can be restricted by default. An operator can choose not to keep restrictions on the recorded footage when removing restrictions on the live video stream.
During the creation process of a playback restriction of a restricted live stream, you will not be able to add additional or remove existing cameras. You can however, edit the playback restriction after the restriction has been created and then remove or add additional cameras.
  1. In Live or Playback mode, click Video restrictions > View to open the Video restrictions list dialog.
  2. In the Video restrictions list, use the filters and search field to locate the restrictions you want to remove.
    Live restrictions are displayed at the top of the list and each live restriction is marked with a green LIVE icon.
  3. Select the live restrictions you want to remove and click Remove to open the Remove live restrictions dialog.
  4. In the Remove live restriction dialog, select Create restriction on recorded footage to create a playback restriction on the live restriction you are removing.
    Clear the Create restriction on recorded footage check box if you do not want to create a playback restriction to replace the live restriction you are removing.
  5. Click Remove live restriction to remove the selected live restriction and open the Remove live restriction dialog.
  6. In the Remove live restriction dialog, click Close when the removal process is done. Click Details for a detailed overview of the removal status.
