Editing video restrictions
You can edit existing video restrictions, depending on your user rights, for example changing the restriction start and end times, adding additional cameras, and updating the restriction heading and description.
You can only edit the restriction settings for the restricted video. Any evidence lock settings created on the restricted video must be edited separately.
You can only edit or remove restrictions on cameras located on the site you are currently logged on to.
