Edit one or more live restrictions
You can only change the restriction start time for live restrictions.
You can access the Video restrictions list from either Live or Playback mode.
  1. In Live or Playback mode, click Video restrictions > View to open the Video restrictions list dialog.
  2. In the Video restrictions list, use the filters and search field to locate the restrictions you want to edit.
  3. Select the restrictions you want to edit and click Edit to open the Edit live restriction dialog.
  4. In the Edit live restriction dialog, update the Interval start field and click Save changes to display the progress of the updates in the Edit live restriction dialog.
  5. When the changes have been updated in the Edit live restriction dialog, click Close to close the dialog.
    You can click Details to get a more detailed overview of the update.
