View restricted video
Operators assigned permissions to view restricted video or audio, can view the material normally. When displayed, the footage will contain a warning that the material is currently restricted.
Operators not assigned permissions to view restricted video or audio will not be able to view the footage and the camera containing the material will be marked as restricted in the user interface.
Restricted videos can be viewed in the Live or Playback mode by opening the camera view directly and playing the video material.
You can also open a camera view from the Video restrictions list if you are assigned sufficient user permissions to access the list.
- In Live or Playback mode, click Video restrictions > View to open the Video restrictions list dialog.
- In the Video restrictions list, use the filters and search field to locate the restrictions you want to view.
- Select the restrictions you want to view and click View.
Some restrictions may contain multiple cameras and you can only view 100 cameras at the same time.
