Edit one or more playback restrictions
You can update all settings of multiple playback restrictions – changing the headline, description, interval start and end times as well as adding additional cameras to the restrictions.
You can access the Video restrictions list from either Live or Playback mode.
- In Live or Playback mode, click Video restrictions > View to open the Video restrictions list dialog.
- In the Video restrictions list, use the filters and search field to locate the restrictions you want to edit.
- Select the restrictions you want to edit and click Edit to open the Edit playback restriction dialog.
- In the Edit playback restriction dialog, update any relevant restriction settings and click Save changes to display the progress of the updates in the Edit playback restriction dialog.
- When the changes have been updated in the Edit playback restriction dialog, click Close to close the dialog.
You can click Details get a more detailed overview of the update.
