Milestone AI Bridge resource location
All required Milestone AI Bridge resources can be downloaded from the Amazon ECR Public Gallery - milestonesys/aibridge public repository or from the Milestone download page, depending on which Milestone AI Bridge components you want to download.
Container management software
Milestone AI Bridge can be hosted on both Docker Compose and Kubernetes. Chose the download that matches your runtime environment.
Docker Compose
  • Log on to the Milestone download page, filter the page by product (for example AI Bridge) and by the desired version.
  • Download the Milestone AI Bridge resource file and extract files from the aibridge_compose_deployment folder.
The Milestone download page can be accessed here: https://www.milestonesys.com/downloads/
You must have a My Milestone account to access the download page.
For more information about deploying Docker Compose for Milestone AI Bridge, see Installing Milestone AI Bridge (Docker Compose)
Kubernetes
The Kubernetes Helm chart can be downloaded from the Amazon ECR Public Gallery - milestonesys/aibridge public repository, located here: https://gallery.ecr.aws/milestonesys/aibridge.
You do not need an Amazon account to access the repository.
For more information about deploying Kubernetes for Milestone AI Bridge, see Deploying Milestone AI Bridge (Kubernetes)
Container images
The container images required for Milestone AI Bridge operations are located in the Amazon ECR Public Gallery - milestonesys/aibridge public repository, located at https://gallery.ecr.aws/milestonesys/aibridge. The containers will be retrieved when deploying Milestone AI Bridge using Docker Compose or Helm charts but can also be manually downloaded individually.
For more information about the Milestone AI Bridge containers, see Milestone AI Bridge containers.
The offline Milestone AI Bridge Reference manual
The Milestone AI Bridge reference manual contains reference material about the Milestone AI Bridge GraphQL API and its elements. The reference manual can be accessed as a web page hosted by Milestone AI Bridge and you can also download and unpack the reference material on your local machine.
  • Download the Milestone AI Bridge resource file and extract the aibridge_reference_manual folder.
For more information about the Milestone AI Bridge Reference manual, see The Milestone AI Bridge reference manual.
The Milestone XProtect Processing Server Admin Plugin
If you want to use the all the features provided by Milestone AI Bridge and you are running Milestone XProtect 2022R3 or newer, you must install the Milestone XProtect Processing Server Admin Plugin for the XProtect Management Client.
Download the Milestone XProtect Processing Server Admin Plugin
  • Download the Milestone AI Bridge resource file and extract the VideoOS.ProcessingServer.Plugin.Admin.Installer.exe file from the aibridge_xprotect_plugin folder.
For more information about the Milestone XProtect plugin, see Install the Milestone XProtect Processing Server Admin Plugin
Milestone XProtect patches
If you are running XProtect 2022R2 or XProtect 2022R1, you must apply the appropriate patch to your XProtect installation before installing the Milestone XProtect Processing Server Admin Plugin.
For XProtect 2022R3 and later, the updates contained in the patch are part of the product by default.
Download the appropriate XProtect patch
  • Download the Milestone AI Bridge resource file and extract the xprotect_patch_2022_R1 or xprotect_patch_2022_R2 files from the aibridge_xprotect_patch folder.
Milestone AI Bridge does not support XProtect 2021R2 and older.
For more information about Milestone XProtect patches, see Update your Milestone XProtect installation
The Milestone AI Bridge resource file
The Milestone AI Bridge resource file is a zip file that contains many resources which you will need for installing, deploying, setting up, and maintaining your Milestone AI Bridge solution.
A Milestone AI Bridge resource file is created for one specific version of Milestone AI Bridge and can be downloaded from the Milestone download page.
Milestone AI Bridge name
The Milestone AI Bridge resource file is named Milestone_AI_Bridge_<Version>_Resources.zip, where <Version> is the version of Milestone AI Bridge the resource file is created for, for example Milestone_AI_Bridge_2.0.0_Resources.zip.
Contents of the Milestone AI Bridge resource file
The Milestone AI Bridge resource file contains the following:
File Type Description
aibridge_compose_deployment Folder Contains all Docker resource files for Milestone AI Bridge.
aibridge_reference_manual Folder Contains the offline Milestone AI Bridge reference manual.
aibridge_xprotect_patch Folder Contains the Milestone AI Bridge patch files required for XProtect 2022R2 or XProtect 2022R1.
aibridge_xprotect_plugin Folder
Contains the Milestone XProtect Processing Server Admin Plugin which must be applied to each XProtect Management Client that is to connect to Milestone AI Bridge.
Milestone_AI_Bridge_EULA_en-US.pdf File Contains the End-User License Agreement for Milestone AI Bridge.
README.md File Contains specific information about the contents of the Milestone AI Bridge resource file.
