The Milestone AI Bridge reference manual
The Milestone AI Bridge reference manual provides reference material about the Milestone AI Bridge GraphQL API and its elements. It also contains the GraphiQL and GraphQL Voyager services, which are two GraphQL services that you can use to test your GraphQL queries and get an overview of the GraphQL API.
Accessing the reference manual
The reference manual can be accessed as a web page hosted by Milestone AI Bridge but only if you have deployed Milestone AI Bridge to run in debug mode.
If Milestone AI Bridge is running in production mode, you cannot access the Milestone AI Bridge reference manual unless you download a copy and access the manual locally.
The reference manual is accessed through port 4000 (for example http://localhost:4000).
If you are using Kubernetes
You can access the Milestone AI Bridge Reference Manual from outside the Kubernetes cluster by using the following URL: http://<kubernetes-cluster-hostname>:4000 where <kubernetes-cluster-hostname> is the hostname of your Kubernetes cluster.
The GraphiQL query interface is accessed by using the following URL: http://<kubernetes-cluster-hostname>:4000/api/bridge/graphql.
GraphQL Voyager is accessed by using the following URL: http://<kubernetes-cluster-hostname>:4000/voyager.
If you are using Docker Compose
You can access the Milestone AI Bridge Reference Manual on the host running Docker Compose by using the following URL: http://<hostname-of-aibridge>:4000 where <hostname-of-aibridge> is the hostname of your machine.
The GraphiQL query interface is accessed by using the following URL: http://<hostname-of-aibridge>:4000/api/bridge/graphql.
GraphQL Voyager is accessed by using the following URL: http://<hostname-of-aibridge>:4000/voyager.
Download a local copy
The Milestone AI Bridge reference manual can also be downloaded and unpacked locally. You can access the content by opening the Index.htm file in the aibridge_reference_manual folder in a browser.
The GraphiQL and GraphQL Voyager services will not be available when opening a downloaded local copy of the Milestone AI Bridge reference manual.
For more information about where to download Milestone AI Bridge resources, see Milestone AI Bridge resource location.
