Deployment overview
There are several steps in installing and configuring the integration between XProtect VMS, Milestone AI Bridge, and your IVA applications.
Some of the steps are configuration tasks in XProtect Management Client or installations on computers with XProtect Management Client. The administrator of the XProtect VMS typically handles these steps, if necessary with help from the IVA app integrator, for example when installing and configuring a new integration.
Other steps are performed on systems outside of XProtect Management Client and the XProtect VMS installation and are typically handled by the IVA app integrator.
Some steps are independent of each other, while others need some degree of coordination between the XProtect VMS administrator and the IVA app integrator.
This is how we recommend that the steps are completed and typically by whom:
Step Roles Action
1 Integrator and administrator
Based on the analytics requirements and the size of the XProtect VMS installation, determine the most applicable Milestone AI Bridge integration solution.
Learn more
Architecture overview and system components
Ports used by the integration
Licensing
Minimum system requirements
Compatibility
2 Administrator
If the XProtect VMS is secured using certificates, share the certificates with the IVA app integrator.
Learn more
Secure the connection between XProtect VMS and Milestone AI Bridge
3 Administrator
Create a basic user forMilestone AI Bridge and share its user credentials with the IVA app integrator.
Remember to add the basic user to the Administrators role.
Learn more
Create a basic user for Milestone AI Bridge
4 Integrator
Depending on the decision for the Milestone AI Bridge integration made in step 1, create a Linux-based processing server and install all required IVA applications.
Learn more
Create a processing server
5 Administrator
Install a certificate and a plug-in on all computers with XProtect Management Client so Milestone AI Bridge configuration can be performed from these machines.
For XProtect VMS product versions 2022 R1 or R2, you must also install a patch.
Learn more
Secure the connection between XProtect Management Client and Milestone AI Bridge
Install the Milestone XProtect Processing Server Admin Plugin
Install a patch for XProtect Management Client
6 Administrator
Ensure compliance with existing legislation and common practices concerning personal and private data, for example the GDPR regulations.
Learn more
Define the retention time for analytics events
7 Administrator
Subscribe to analytics topics and perform any additional configuration tasks in XProtect Management Client.
Learn more
Analytics data types and formats
View the status of processing servers
View available IVA applications and their analytics topics
Subscribe for video analytics and receive analytics data back
Create rules with analytics events
Add alarms with analytics events
8 Integrator and administrator
Test the integration before deploying to a production environment or initiating daily operations.
Learn more
Test your subscriptions to analytics topics
