Initial configuration tasks
Before you install or immediately after you install the patch for XProtect Management Client and the Milestone XProtect Processing Server Admin Plugin, there are a few configuration tasks that you typically define once.
  • Create the AI Bridge role (optional but recommended).
    Create a basic user and assign to the AI Bridge role so Milestone AI Bridge can connect with your XProtect VMS.
  • Secure the connections between Milestone AI Bridge and your XProtect VMS.
  • Define a retention time for events to comply with GDPR or other laws concerning personal data.
