Secure the connection between XProtect VMS and Milestone AI Bridge
This section is only relevant if you have secured your XProtect VMS using certificates.
You must share the public Certificate Authority (CA) certificate (.cer) and the SSL certificate (.pfx) you use for encrypting your XProtect VMS with your IVA app integrator.
The IVA app integrator must install these certificates on the processing server that has Milestone AI Bridge installed to help secure the connection between the XProtect VMS and Milestone AI Bridge.
See also Secure communication (explained) and Server Configurator (explained)
