Record tab (devices)
The following devices have a Record tab:
Cameras
Microphones
Speakers
Metadata
Recordings from a device are only saved in the database when you have enabled recording and the recording-related rule criteria are met.
Parameters that cannot be configured for a device are grayed out.
Tasks on the Record tab
Name | Description |
Recording | |
Pre-buffer | |
Recording frame rate | |
Storage | |
Select | |
Delete All Recordings | Use this button if you have added all devices in the group to the same server: |
Automatically retrieve remote recordings when connection is restored |
