Streams tab (devices)
The following devices have a Streams tab:
Cameras
The Streams tab lists by default a single stream. It is the selected camera's default stream, used for live and recorded video. If you use adaptive playback, two streams must be created.
Tasks on the Streams tab
Name | Description |
Add | Click to add a stream to the list. |
