Specify recording frame rate
You can specify the recording frame rate for JPEG.
In the Site Navigation pane, select Devices.
Select the relevant device in the Overview pane.
On the Record tab, in the Recording frame rate: (JPEG) box, select or enter the recording frame rate (in FPS, frames per second).
