How to Change Axis Cloud Access Ports
Axis Cloud Access installs several Windows services using predefined network ports. They can be manually reassigned by updating the AdapterConfig.txt and local-config.json files. This should be done only in case of conflicts, when ports are already in use by other applications. This affects only the ACA application behavior and is not related to XProtect operation.
(Optional) Back up your old configuration before you make any changes.
AdapterConfig.txt (Service Port Definitions)
Located in the installation directory (C:\Program Files (x86)\Milestone\XProtect Recording Server\Drivers\NativeDrivers\resources\AdapterConfig.txt), the file defines the ports used by internal ACA components.
Configuration by default looks like:
dds_host=127.0.0.1:7000
dds_rest=127.0.0.1:8301
dcs_host=127.0.0.1:7001
mss_host=127.0.0.1:7007
xpt_host=127.0.0.1:7010
mev_host=127.0.0.1:7010
syslog_host=127.0.0.1:514
secure_grpc=off
log_level=debug
User Configuration Directory
AxisCloudAccess stores user-specific configuration under the User folder. For example, usually it is: C:\ProgramData\Milestone\XProtect Axis Cloud Access\local-config.json. Inside, the file contains port settings for each ACA microservice.
"services": [
"name": "DDS",
"env": [
"ACCAS_SERVICE=127.0.0.1:9999",
"SERVICE_ADDRESS=:7000",
"SERVICE_ADDRESS_HTTP=:8301"
"name": "VCS",
"env": [
"SERVICE_ADDRESS=:7001"
"name": "WSS",
"env": [
"ACCAS_ADDRESS=127.0.0.1:9999",
"SERVICE_ADDRESS=:7007"
"name": "ACCUI",
"env": [
"HTTP_PORT=8888",
"DDS_ADDRESS=127.0.0.1:7000",
