Axis Cloud Access logs and diagnostics
When troubleshooting issues with ACA - such as onboarding failures, connectivity problems, or metadata issues - log information can help identify the root cause.
The following log sources are relevant when investigating ACA‑related issues:
Axis Cloud Access writes its service logs to: C:\ProgramData\Milestone\XProtect Axis Cloud Access\Logs.
Axis Cloud Access service logs
These logs contain information related to service startup, cloud communication, onboarding, and device operations.
Recording server logs are located here: C:\ProgramData\Milestone\XProtect Recording Server\Logs.
Milestone XProtect Recording Server logs
Issues related to device discovery, communication, or driver interaction may be reflected in the Recording Server logs.
