Configure XProtect Management Server Failover (wizard)
When you select Configure XProtect Management Server Failover from the Management Server Manager tray icon, you get one of the following messages:
To learn more about the supported products, see Compatibility.
Make sure that you have installed the XProtect Management Server Failover component on the computer, see Install XProtect Management Server Failover.
You have started the configuration process, see Configure the failover cluster .
From this page you can:
Apply failover license, see Add a license for XProtect Management Server Failover.
Download server certificate on your computer, see Download the server certificate to access the failover web console.
Change current password for authentication, see Change the password for authentication.
Remove existing configuration, see Remove the existing failover cluster configuration.
