After you configure the failover cluster
To make sure your VMS system can connect to the running management server seamlessly, you must make some addition configuration steps.
Connection
The remote servers and clients use the management server address to connect to the VMS system. To update the management server address on all components, you must:
Encryption
Depending on the certificate you want to use to encrypt the connection to the failover web console, you must do one of the following actions:
