Connect to the VMS system from the clients
Replace the hostname of the management server with the cluster address when logging in from the following clients:
  • XProtect Management Client
  • XProtect Smart Client
  • XProtect Mobile client
  • XProtect Web Client.
You replace the hostname on the clients mentioned above to ensure your users always connect to the running management server and your system remains operational when a failure on the management server host occurs.
