Connect the server VMS components to the system
To connect a server component to the failover cluster, you must register the following server components with the cluster address.
Change the management server address on the recording server
  1. On the recording server computer, right-click the server manager tray icon and click Server Configurator.
  2. In Server Configurator, click Registering servers.
  3. Specify the cluster address and the selected protocol (HTTPS or HTTPS) and click Register.
If the change is successful, a confirmation window appears.
Change the management server address on the mobile server
  1. On the mobile server computer, right-click the Mobile Server Manager tray icon and click Management server address.
  2. Specify the cluster address and the selected protocol (HTTPS or HTTPS) and click OK.
  3. The Mobile Server service restarts and the tray icon turns green.
Change the management server address on the DLNA server
  1. On the DLNA Server computer, right-click the XProtect DLNA Server Manager tray icon and click Management server address.
  3. The XProtect DLNA Server service restarts and the tray icon turns green.
Change the management server address for Milestone Open Network Bridge
  1. On the computer that runs Milestone Open Network Bridge, right-click the Milestone ONVIF Bridge tray icon and click Configuration.
  2. On the Surveillance Server Credentials page, in the Management server field, specify the cluster address and the selected protocol (HTTPS or HTTPS) and click OK.
