BriefCam Troubleshooting Guide
Why is the processing failing and I'm seeing Can't open codec : 27 in the log file?
Version2024r2
LanguageEnglish
If you fail to process any video files and you see in the log the following lines:
    2018-12-18 14:29:31,512 0x00001c40
WARN  [h264_cuvid @ 0000021B0A03F500] Cannot load cuvidGetDecodeStatus2018-12-18 14:29:31,512 0x00001c40
WARN  [h264_cuvid @ 0000021B0A03F500] Failed loading nvcuvid.2018-12-18 14:29:31,512 0x00001c40
ERROR Throw: Can't open codec : 27. In BriefCam::VideoNative::FFMpegDecoder::OpenDecoder [FFMpegDecoder.cpp :477]
This means that you are either missing the NVIDIA driver or you have a wrong version of it installed. For information about downloading the correct driver, see Windows Site and Network Topology.Windows Site and Network Topology
