BriefCam Administrator Guide
Version2025 R1
LanguageEnglish
All BriefCam administration activities are carried out in the BriefCam Administrator Console. This Web-based administration application is easy to use and provides administrators with standardized browser-based remote access from any location.
The BriefCam Administrator Console is used for standalone deployments and for multi-site deployments (comprised of multiple site systems and a central Hub). This guide is relevant for all these deployments.
In multi-site deployments, each BriefCam (on the sites and the Hub) has a separate Administrator Console that only controls the local BriefCam administration.
See also:
Initial Set Up
Deployment Configuration
Camera and VMS Configuration
License Mechanism
Permissions
User and Group Management
Environment Settings
Maintenance and Data Retention
Backups
User Data and Security
Security Settings
