Timeline settings
The Timeline settings let you specify the general settings for the timelines in XProtect Smart Client.
If available, the Follow server column lets you specify that you want your XProtect Smart Client to follow the recommended settings of the server. Certain settings are server-controlled, in which case, configuration on the server decides whether you can override the settings.
Name |
Description |
Incoming audio Outgoing audio Additional data Additional markers Bookmarks Motion indication All cameras timeline |
See Configure what to show on the timeline tracks. |
| Playback | |
Hide the timeline during inactivity Hide the timeline in Smart Wall views |
See Hide the main timeline |
