Show or hide device information
You can show or hide information about devices on a smart map. This is useful, for example, when you want to increase or reduce the amount of content on your smart map.
  1. Select the view that contains the smart map that you want to work with.
  2. Click Show or hide layers and custom overlays.
  3. Select or clear the check boxes for the information to show or hide.
