XProtect Smart Wall
You can create any number of video walls. Configuring a video wall is a two-step process. First, you do the main part of the configuration in XProtect Management Client. Then, if you want operators to manually push content onto the video wall, you add a Smart Wall control
En grafisk representation av en videovägg som låter dig kontrollera vad som visas på de olika bildskärmarna. to dedicated views in XProtect Smart Client. See also Smart Wall-kontroll (förklaring).
In XProtect Management Client:
- Create the Smart Wall definition and set the general properties, including the name and the properties of the view items. See also Create Smart Wall definitions.
- Add the Smart Wall monitors, set their size and position relative to the physical monitors of your video wall. See also Add Smart Wall monitors and Position Smart Wall monitors . The Smart Wall control in XProtect Smart Client matches these settings and shows how the monitors are organized, for example next to or below each other.
- (optional) Create the empty presets
En fördefinierad layout för en individuell bildskärm i XProtect Smart Client. Förinställningar innehåller förangivna inställningar som fastställer vilka kameror som ska visas och hur innehållet struktureras på varje skärm på videoväggen. that are required to define the monitor layout and add the default cameras at a later stage. See also Create presets for your Smart Wall. -
(optional) For each monitor, select a preset, define its layout, and add the default cameras. See also Define monitor layout and add cameras.
When to use presets? If you want operators to push cameras and views onto the Smart Wall manually, presets are not required. However, if you plan to use rules to automatically change what is displayed on the video wall, you must define presets.
In XProtect Smart Client:
- Allow operators to push content onto the video wall, then create the views you need, and add the Smart Wall control. See also Lägg till Smart Wall-kontroller till vyer.
With the Smart Wall control you can drag-and-drop or send cameras, entire views, and other types of content to individual monitors.
- Enable operators to change the view layout of individual monitors that are defined in XProtect Management Client. See also XProtect Smart Wall.
- Enable operators to change the presets
En fördefinierad layout för en individuell bildskärm i XProtect Smart Client. Förinställningar innehåller förangivna inställningar som fastställer vilka kameror som ska visas och hur innehållet struktureras på varje skärm på videoväggen. already associated with a monitor. See also Ändra Smart Wall-förinställningen.
To configure a Smart Wall definition, you must first create it in XProtect Management Client. Repeat the following steps for each Smart Wall definition that you want to create:
- In XProtect Management Client, expand Client and select Smart Wall.
In the Smart Wall pane, right-click Smart Wall Definitions and select Add Smart Wall. Ett fönster visas.
- Specify the settings for the Smart Wall.
- In the General View Item Properties settings, specify if you want system status information and title bars to appear above the cameras in the Smart Wall.
- Click OK. The Smart Wall definition is added to the Smart Wall pane.
- Next, add the Smart Wall monitors. See also Add Smart Wall monitors .
When you have created your Smart Wall definition, you must add the Smart Wall monitors that your video wall consists of and specify the monitor settings.
You have created at least one Smart Wall definition. See also Create Smart Wall definitions.
Steps:
In the Smart Wall pane, right-click your Smart Wall definition and select Add Monitor. Ett fönster visas.
- Configure the size and aspect ratio of the monitor, so that it matches one of the physical monitors on the video wall.
Specify the preset behavior.
Empty preset - control what happens in XProtect Smart Client when a preset is already applied, and the operator applies an empty preset:
Preserve - keep what is currently being displayed
Clear - replace the current content with the empty preset
Empty preset item - control what happens in XProtect Smart Client to individual preset items when a preset is already applied, and the operator applies a preset with empty preset items:
Preserve - keep what the preset item is currently displaying
Clear - replace the preset item with the empty preset item
Element insertion - control what happens in XProtect Smart Client when an operator
En professionell användare av ett XProtect-klientprogram. drags a camera onto an item in the preset:-
Independent - replace the camera already in the preset item with the new camera
Linked - push the content from left to right from where you inserted the new camera
- Klicka på OK för att spara dina ändringar.
- Keep adding Smart Wall monitors until the number equals the number of physical monitors.
- Next, position the monitors. See also Position Smart Wall monitors .
When you have added the monitors to your Smart Wall definition, you must position the different monitors to match the setup of the physical monitors on the video wall.
You have added the monitors to your Smart Wall definition. See also Add Smart Wall monitors .
Steps:
- In the Smart Wall pane, select your Smart Wall.
In the Properties pane, click the Layout tab.
Click the Edit button. Ett fönster visas.
- Drag and drop the monitors to position them, or use the arrows.
- Click
or
to zoom in or out. - If you have not already specified the size and aspect ratio of the monitors, you can do it now.
- Klicka på OK för att spara dina ändringar. The positioning and sizing of monitors are visualized in the Smart Wall control in XProtect Smart Client.
- Next, add presets
En fördefinierad layout för en individuell bildskärm i XProtect Smart Client. Förinställningar innehåller förangivna inställningar som fastställer vilka kameror som ska visas och hur innehållet struktureras på varje skärm på videoväggen.. This is a requirement for specifying the layout of Smart Wall monitors and adding cameras to your monitors. See also Create presets for your Smart Wall.
With presets, you configure what your video wall or specific monitors show when used with a specific preset. Create as many presets as you need.
Steps:
- In the Properties pane, click the Presets tab.
Click Add New. Ett fönster visas.
- Enter a type and possibly also a description.
- Repeat the steps above for each preset that you want to add.
- Next, add layout and cameras to the monitors. See also Define monitor layout and add cameras.
To control what is displayed on the individual monitors, you must define a layout, for example 2x2, and then possibly add cameras. In the following example, there are four cameras. Operators can always change these cameras manually in XProtect Smart Client.
Presets can also be empty with only the layout defined. This is useful, for example if you want operators to only push cameras manually to the video wall.
For each monitor that you want to add cameras to, a preset must be in place. See also Create presets for your Smart Wall.
Steps:
- In the Smart Wall pane, select the monitor that you want to add cameras to.
- Click Edit. Ett fönster visas.
Click
. An additional window appears. -
Select a layout and click OK. The layout appears on the right-hand side of the first window.
- From the Device Groups or Recording Servers tab, drag the cameras onto the preset items - one by one. You can also leave preset items empty.
- Repeat the steps above for each monitor that you want to configure.
- Now you can start using your Smart Wall in XProtect Smart Client.
You must also configure the operators' user rights for using XProtect Smart Wall. See also Specify user rights for XProtect Smart Wall.
