Direct streaming
In XProtect Web Client, you can use direct streaming in both the single-camera view and the grid view.
The video stream falls back from direct streaming to transcoding if:
The direct streaming feature has been disabled in Management Client, or the requirements have not been fulfilled (see Requirements for direct streaming).
The codec of the streaming camera is different than H.264.
The video cannot start playing for more than ten seconds.
The frame rate of the streaming camera is set to one frame per second (1 FPS).
The connection with the server or with the camera has been lost.
You use the privacy masking feature during live video.
