XProtect Web client
Direct streaming
In XProtect Web Client, you can use direct streaming in both the single-camera view and the grid view.
The video stream falls back from direct streaming to transcoding if:
  • The direct streaming feature has been disabled in Management Client, or the requirements have not been fulfilled (see Requirements for direct streaming).
  • The codec of the streaming camera is different than H.264.
  • The video cannot start playing for more than ten seconds.
  • The frame rate of the streaming camera is set to one frame per second (1 FPS).
  • The connection with the server or with the camera has been lost.
  • You use the privacy masking feature during live video.
