XProtect Web client
Requirements for direct streaming
XProtect Web Client supports direct streaming in live mode.
You can use direct streaming to monitor more than 100 concurrent live video streams at Full HD 30 FPS. To use this feature, you must:
  • Use cameras that support the H.264 codec.
  • Enable the direct streaming feature in XProtect Web Client (see Settings).
