No longer allow HTTP connections
You can clear the setting that allows you to log in to XProtect VMS system using a network protocol with a connection that use an older security model (HTTP). See Allow connections that use an older security model (HTTP).
On the global toolbar, select User menu.
Select Login information.
Select Clear.
Select OK.
