Allow HTTP connections
Version2026 R2
LanguageEnglish
If your XProtect VMS system doesn’t have a certificate installed, you can’t connect with the newest available security model in XProtect. The security model is based on the HTTPS network protocol.
  • To allow HTTP connections, select Remember my choice. Do not show this message again.
Note
If your XProtect Smart Client is connected to a XProtect VMS system or a federated site using the older security model (HTTP), a Not secure information message is shown to the left of the global toolbar.
See also No longer allow HTTP connections.
