Change the sound of the sound notifications
Version2026 R2
LanguageEnglish
Having different sound notifications on different computers with XProtect Smart Client can be useful. The sound file plays whenever events or motion are detected. You can change the sound file to have a different notification sound on each computer, but you need administrator rights to do so.
The sound file, called Notification.wav, is located in the XProtect Smart Client installation folder. Typically: C:\Program Files\Milestone\XProtect Smart Client.
  • If you want to use another .wav file, simply name the file Notification.wav and copy it to the XProtect Smart Client installation folder.
Note
Using different sound files for different cameras or distinguishing between event- and motion-detection is not supported.
