Connect recovered sub-sites
Version2026 R2
LanguageEnglish
If some sub-sites are unavailable when you log in, XProtect Smart Client can retry them in the background while you work with the connected sites. When sub-sites become available, you choose when to connect them.
Before you begin
Important
When you connect to a recovered sub-site, it resets all open views, discards unsaved changes, and restarts video playback. Searches and other ongoing activities are also interrupted.
Save any changes you want to keep and finish any activities you do not want interrupted before connecting recovered sub-sites.
Connect available sub-sites
When the Sub-sites available for connection notification appears, decide whether it is a suitable time to reset your workspace.
To connect the recovered sub-sites now:
  1. Save your changes and select Connect in the notification.
  2. Wait while Smart Client reloads the configuration. Your workspace is reset, the recovered sub-sites are connected, and their cameras become available in the Cameras section.
To connect the sub-sites later:
  1. Open the user menu and select the server name next to the connection-status indicator.
  2. In the Login information window, sub-sites that are recovered and ready to connect have the status Available - Pending connection.
  3. Select the sites you want to connect and select Connect.
If Smart Client asks you to allow an unsecure connection
Some recovered sub-sites may be available only through an unsecure connection that you have not already allowed.
  1. In the notification stating that the sub-sites do not use the latest security model, select Allow.
    Selecting Allow only allows the unsecure connection. It does not connect the sub-sites or reset your workspace.
  2. Review the prompt and accept if you want to allow the connection anyway.
  3. Wait while Smart Client retrieves the sub-site configurations in the background.
  4. When the Sub-sites available for connection notification appears and when you are ready for the workspace to reset, select Connect.
