Sub-site recovery
Sub-site recovery helps you start working in XProtect Smart Client even when some sub-sites in your system are slow or temporarily unavailable. Instead of waiting for every sub-site to respond during login, Smart Client lets you work with the available sites while it retries the unavailable sites in the background.
This is particularly useful in large federated systems, where a few unavailable sub-sites could otherwise delay access to the rest of the system.
Recovery and connection
When an unavailable sub-site becomes available again, it is recovered, but it is not automatically connected to your session. You receive a notification in Smart Client when recovered sub-sites are ready to connect, and you decide when to connect them. If several sub-sites recover at the same time, you can connect them together instead of interrupting your work for each site individually.
The Sub-site recovery setting determines how long Smart Client waits for slow sub-sites during login and how frequently it retries unavailable sites afterward. See sub-site recovery in Advanced settings.
Why you control when to connect sub-sites
Connecting recovered sub-sites reloads the system configuration. This can interrupt your work by resetting open views, discarding unsaved changes, and restarting video playback. Searches and other ongoing activities are also interrupted.
For this reason, Smart Client does not automatically connect recovered sites. Instead, it lets you continue working until you are ready to connect them. Before you connect to available sub-sites, save any changes you want to keep and finish any activities that you do not want interrupted.
