[en] Generate a script reference
Version2026 R2
SprogDansk
[en] You can generate a Markdown reference file (.md) with all available script commands, syntax examples, and actions supported by your current installation of XProtect Smart Client. The script reference is your on-demand quick reference for supported commands and syntax, eliminating guesswork and syntax errors when authoring scripts.
[en] Steps
  1. [en] In XProtect Smart Client, on the global toolbar, select Settings and more SC_GlobalToolbar_SettingsAndMore_icon.jpg and then Settings.
  2. [en] Select the Scripts tab.
  3. [en] Select Generate script reference….
  4. [en] In the dialog that appears:
    • [en] Select Include configuration items if you want the reference to include items specific to your VMS setup, such as views, user-defined events, and outputs.
    • [en] Deselect Include configuration items  if you only want general, built-in client commands.
  5. [en] Select a destination folder and name the Markdown file (.md), then select Save.
