[en] Verify a Smart Client script
[en] You can verify a Smart Client script (.scs) before deploying it to confirm that the script file is valid, uses supported syntax/actions, and runs without errors.
[en] Prerequisites
[en] An
.scsscript file stored on a local or accessible network drive.
[en] Steps
[en] In XProtect Smart Client, on the global toolbar, select Settings and more
and then Settings.[en] Select the Scripts tab.
[en] Select Verify script….
[en] In the file browser, select the
.scsfile you want to test, then select Open.[en] Review the verification result displayed in the dialog:
[en] If the script is valid, a confirmation message tells you it passed validation.
[en] If the script contains errors, review the reported issues, such as unsupported commands, invalid XML formatting, or schema incompatibilities, before you run the script again.
